1 - 10 of 10 Posts
I was thinking about painting my wheel...but do I use any kind of paint or is there a special paint for the wheel?....thanks in advance guys...
Auto Zone sells rim paint. Just be sure to clean your rims real good so that the paint will stick better. I'm needing to repaint my SH rims, espeically now that I took the tires off
okie...need a little advice guy...if i painted my rim with Duplicolor wheel coating and then use the regular not hight temperatur clear coat....are they going to peel off..?
I didn't use high temp clear coat on my wheels and i have not noticed any peeling yet
you dont have to paint it with wheel paint...i painted mine with high temp engine paint haha...i also used a wheel clear coat
Make sure you wet sand with rim cleaner to get all the dirt/brake dust off of the rims and make it as clean as possible before you start painting so that the paint will stick really good.
1 - 10 of 10 Posts
