1 - 3 of 3 Posts
are you talking about a vacuum line? there should be some kind of sticker somewhere under the hood that shows the vacuum line diagram. go by that, or check your manual or online manual. i have no idea which hose is number 19
Try http://www.alldata.com/
Aldata will most likely show you. It is 15 bucks per year, but it is pretty easy to use.
No idea what it dose. What area of the motor did you disconnect it from.
Is your car an S. Model?
1 - 3 of 3 Posts
