[Project Car] 1986 Prelude "Lucy"
1817 Views 31 Replies 2 Participants Last post by  Stub
3
I purchased the car listed in this post:
Decided to call it "Lucy". It does have rust, but the rust isn't as bad as I expected. Of course I can always find more rust after taking things apart, which is often the case. We'll see, but I'm optimistic.
Car Tire Vehicle Wheel Automotive tire
Automotive parking light Car Land vehicle Vehicle Vehicle registration plate
Car Land vehicle Vehicle Automotive parking light Vehicle registration plate
See less See more
  • Like
Reactions: 1
1 - 20 of 32 Posts
3
Looking under the car the first thing I noticed is the exhaust was hacksawed off before the catalytic converter. Not sure why that was done. The engine bay has an extra addon. After doing some research I determined it's a Travel Cruise OEM Replica Series Datsun cruise control device. Very interesting, but stupid. I wouldn't be surprised if it's the culprit for the performance issues. The installation job looks sketchy.
Vehicle Car Hood Motor vehicle Automotive design
Motor vehicle Automotive fuel system Automotive tire Gas Automotive exterior
Electricity Automotive tire Electrical wiring Gas Cable
See less See more
  • Like
Reactions: 1
Put in a new battery and started Lucy up. It started then immediately turned off. When I use starting fluid it does run off the starting fluid and then shut off. The fuel pump for this car should make a regular clicking noise while it's pumping, which I don't hear, so either the fuel pump or the wiring to it is bad. The tank is 1/4 full and hopefully that gas is still good.
Edit: If something is blocking fuel from flowing down the line, the pump won't click. That turned out to be the case.
2
I tested the wiring to the pump and it does have voltage. I tested the pump itself by jumping 12V power to it and it does click a couple times, indicating that it works. Next I did a flow test, to verify that the pump isn't weak. I removed the fuel hose after the filter in the engine bay, then jumped the pump again and I do get fuel flowing out. (I also noted that the fuel filter is way way past its expiration date.) So the fuel pump is running but the engine doesn't run unless I give it starting fluid. That implies to me that the problem is with the carburetor. There isn't a mixture screw on this carb (thanks California) so I can't play with that. Maybe the valve in the carbs is stuck closed so no fuel is getting in the float bowl? I removed the air cleaner to inspect the carburetors and noticed there is this black gunk that looks like oil sludge. At this point I think the carbs are messed up, so the next step is to replace the carbs. I have a pair of webers ready to go so now is the perfect opportunity to use them.
Hood Motor vehicle Automotive lighting Automotive tire Fluid
Rim Gas Automotive wheel system Auto part Composite material
See less See more
  • Like
Reactions: 1
2
Removed the carburetor and the intake manifold. It's not that hard until it comes to the bottom middle bolt on the intake manifold. The problem is the intake manifold is in the way of the intake manifold nut so it's hard to get a tool in that you can then move enough to loosen the bolt. I wanted to use a crowfoot wrench, which is an attachment for a ratchet. I have a crowfoot wrench set, but it doesn't have the 12mm adapter. 🔫:mad: I doubt if the crowfoot would have worked anyway since there's a nipple for the PCV hose that is also in front of the nut, but it would have been nice to try. I tried using a wrench with a flexable head but turning it while keeping the head on the nut was too difficult. What worked for me is this: remove the air cleaner, remove the blowby chamber, remove the carb, remove the air cleaner support beam next to the black PCV box, unbolt the PCV box, remove the top hose on the box, then pop it out of the engine and pull it back. Take an offset 12mm wrench and remove the nut.
Lord have mercy may nobody have an intake manifold gasket leak on this car.
Motor vehicle Automotive tire Car Automotive exterior Vehicle
Motor vehicle Automotive tire Automotive exterior Bumper Gas
See less See more
  • Like
Reactions: 1
2
I finished bolting in the new carbs. Turned out to be a bit more difficult because the bolt holes were just a few millimeters off so I had to make them a bit bigger with a drill. The port for the brake booster is too long and it bumps into the engine, so I had to find an L-shaped adapter. The lever on the linkage for the throttle cable bumps into the engine so I'll have to move things around to a placement that works.
I plugged some of the nipples for coolant and rigged something for the temperature sensor attachment. I'm not happy with the setup yet. It's going to take some trial and error, plus me measuring things and buying hose adapters online, until I'm satisfied. One thing I hate is having to go to a hardware/autoparts store and trying to rig together some series of adapters in the hopes of making things fit. Some things you can only find online.
Vehicle Motor vehicle Rim Automotive exterior Gas
Motor vehicle Gas Engineering Industry Machine
See less See more
  • Like
  • Love
Reactions: 3
Tried starting it. It takes a few tries but it can start and run. The problem is it runs badly and it's backfiring out of the intake. The passenger side carb regularly puffs out fuel/smoke/fire. Also it's very loud because the exhaust pipe was cut before the cat. I made a modest attempt to tune the carbs but I'm new to that process and haven't gotten any results. The gas is at least a year old, so to rule that out as a problem I drained it all out and put in a few gallons of fresh high-octane gas, plus a bit of seafoam. No change. Apparently backfiring out of the carbs is caused by either bad timing or very lean air/fuel mixture. At least there's progress. It does run, but poorly.
The next step is to send it off to get a new exhaust pipe. If I tune the carbs, then add an exhaust, I'd have to tune it again, so I'll go ahead and get a new exhaust bolted/welded on. After that it'll be a process of diagnosing why it isn't performing right and fixing it.
  • Like
Reactions: 1
Ooooh man this brings back memories! Nice work so far.
Thanks! Any tips on how to tune it? Did you have to redo the engine timing?
Timing? Didn't have to to change it much, would have to look at my old posts, but Rjudgy (or something like that) stated a good timing setting that I was using.
Are you using the vacuum advance? I think I remember not using and just capping that off.
What choke size, idle and main jet sizes are you running?
For now I have it capped. I do have nipples for the weber carbs that I'll add later.
I just purchased a pair of Weber 40 DCOE from ebay and bolted them on. Whatever comes stock is what's on there.
Ah ok. For timing as a start you should be ok at least to start with +10-15 deg (no vacuum advance). Once you get the carbs tuned you can advance little by little untill you get best results. Wonder how not having an exhaust connected could be affecting it though, bets to get that fixed first.
Those carbs are hardly a "bolt on mod" that we enjoy with modern cars, those bad boys require a lot of tune/test cycles to make run right (which is where the fun is!!). I had DCOE 40's on my car as well, ran well for the most part but we're a bit rich the the top end, never fixed that... You will want to pull and check the chokes, idle jets and main jets. If your timing is good maybe you are running lean. I would suggest buying a jet kit with assorted sizes to tune it up, and might as well go up to the max choke size while your at it (38mm) I think. The chokes and jets can easily be removed and checked with the carbs mounted, to the engine no worries.
Once you know your choke size, start with the idle jets, those jets run the engine up to about 3000rpm before the main jets take over. Tune the idle jets first for best idle and low rpm performance, then move to the mains.
See less See more
  • Like
Reactions: 1
Worth mentioning is that first you will need to ballance the carbs. There should be an adjuster on the throttle linkage for that. You can do it by using some PVC pipe about the size of those velocity stacks with a right angle connection. Stick the pipe into the drivers side carb then the passenger side carb with your ear on the other end. As you adjust the ballance on the linkage, listen for tone changes through the tube and get both carbs sounding the same. Once they are about equal, your good to move on to tuning.
Interesting technique, but I have an air flow meter to make it easier.
  • Like
Reactions: 1
Lol even better. The airflow will be far more precise. If I get a chance over the next couple of days I'll check the jets I was running to help give you a baseline. I still have the carbs and manifold but will likely sell them, been holding on to them for 15 years!!!
Thanks, a baseline of jet sizes would give me a good starting point.
4
Idle jets. 60/f9
Emulsion tubes f16
Main jets 135
Pump jets 40
Since I assume your motor is mostly stock you may need to be a bit smaller than that. Perhaps 50/f9 idles to get started? Running weber DCOE 40s, choke size 40mm (custom modified 36mm was biggest available) and size 6 Venturi.
Wood Household hardware Nickel Titanium Metal
Cylinder Wood Auto part Metal Steel
Motor vehicle Vehicle Automotive exterior Gas Automotive wheel system
Wood Audio equipment Cylinder Cosmetics Metal
See less See more
That helps me out a great deal. The motor on Lucy is stock (and staying that way :coffee:) so I'm guessing the jet sizes will be different from what you have. On the site Weber jetting calculator they do recommend similar settings. I'm going to order those parts. The exhaust system is finally done (only took two months :rolleyes:) so once those jets arrive I can start tuning!
Font Rectangle Material property Parallel Circle
See less See more
  • Like
Reactions: 1
Excellent, should be a good start. You might find 135 main jet a bit big, but on the other hand in Alberta our altitude is fairly high at 3000ft, so might be a contributing factor, for me needing smaller. Most of the big Weber guys would run 140 and bigger on their A18's back when I was tuning.
I had full header to 2.25" exhaust and a Colt stage 2 cam, no head work. I do remember needing "resistorless" sparkplugs for best combustion, so look into that too. If you search that term on this forum you should find a part number to use.
After a day of trying different things on the carbs to diagnose the problem, I eventually took a look at the spark plugs and did a compression test. Unfortunately that revealed cyl 3&4 are very low. That explains why it ran poorly and was backfiring out of one of the carbs, though I'm surprised it was able to run at all. It's not the end of the car, but now it needs a new engine. What really sucks is I didn't think to do this as soon as I got the car. If I did, I could have stuck the engine from the donor car I have in this one. I'll have to find a mechanic (oh boy here I go again...) that can find and swap in an engine for me. From what I see on car-part.com the engines are about $700 + shipping which isn't so bad.
1 - 20 of 32 Posts
