1 - 13 of 13 Posts
So I acquired a 97' and the only issue is hit has almost nothing under the fron wheel well. in the trunk I found the 'knuckle' and the 'fork' that the strut sits into. So I kind of need to get to move but finding the parts some are type SH and some are universal, I can't seem to find any full parts list for OE or aftermarket full rebuilds.
things still on the car:
wishbone
axels
tire rods
break calipers
Administrator
So you need an SH lower control arm and knuckle.
As well as strut fork and strut.
Junkyard or partout. Maybe ebay. They differ from a Base.
Discussion Starter #4
I have the knuckle and strut fork... the lower control arm is there aswell
Go there and you'll see the diagram of whatever it is you're missing
The question related to your rims is that they are base wheels, the Type SH are different (quick google search will show you it's 5 spoke straight) the wheels that you have go by "Blades" which are found on base models.
Basically make sure your car is a Type SH (run the vin number)
I dont understand what you mean. The rims?
Yes, those are base model rims, I know there are suspension difference between these 2 model, you may want to do some research and then fin you correct parts
Administrator
Bruh, i don't know what I'm missing not where to find them
Well, from the sounds of it, you have everything. Unless you simply need brakes or a hub or something on that knuckle.... How about posting a photo of everything if the catalog is too confusing for you.
1 - 13 of 13 Posts
