Hi guys, I have a Prelude 4th gen (SI non-VTEC 5 speed) that ran well last time it was driven but it has been sitting for years now without being started. It has been in an outdoor but covered location.
This car has sentimental value so I don't want to damage it by just starting it up without doing some work first. Here is my plan to resurrect it... let me know what you think.
1) Drain gas tank from 18mm drain bolt (completed). Was able to reach this without jacking up the back. I blocked the rear wheels and jacked up the front and got a lot more gas out of there. Waited until it dripped very little so I'm pretty sure 99% of the old gas is out of there.
2) Replace fuel filter with new OEM parts while the gas is out of the car.
3) Fill car with 10 gal premium gas and add royal purple injector cleaner and valvoline water remover.
4) Pull spark plugs and add 5 drops or so of Mobil 1 synthetic 5W-30 into each cylinder to lube the rings.
5) While plugs are out replace with new NGK iridium plugs and NGK wires using a bit of anti-seize and dielectric grease.
6) Replace distributor cap and ignition rotor with new OEM parts.
7) Replace air filter.
8) Replace PCV valve with new OEM parts.
9) Replace car battery with new one.
10) Try to start the car.
11) If successful, change oil (mobil 1 5W-30) and filter (TOYO ROKI) and drain plug crush washer and drain, fill and bleed radiator with OEM coolant.
Let me know if I have missed anything. Thanks guys.
