1 - 4 of 4 Posts
Its bearing was making noise,i decided to change the bearing today and did it.bearing noise gone but there is a whining noise when i turn the wheel.i guess some air stucked in system.i didn't disasambled the main cylinder of pump and the plates in it.i believe i did it right.is there someone done tihs before?
I believe air bubbles can be filtered out of the system via the PS reservoir. Contaminated fluid however does not. I would make sure your fluid is clean.
Did you ever figure out what caused the noise? I have the same problem after replacing pump... It has been flushed and bleed several time now still have noise. Any help would be great, Thanks.
1 - 4 of 4 Posts
