Hey everyone
So I was driving my 1991 (JDM) Prelude home from a weekend away and when I hit the motorway my dash went a bit crazy. The speedo dropped to zero, the sports light started flashing and the check engine light came on. The cruise control may have also disengaged but I'm not 100% sure.
I took the first exit off the road and turned my car off. upon turning it back on everything seemed fine until a few minutes down the road when it did it again, same issues (excluding the check engine light, which hasn't come back on, yet).
I took the next exit again and stopped. After a quick call with a friend of a friend who was a mechanic I was told my car would make it home as long as the engine had no performance issues (which it did not).
Throughout the entire drive (around seven hours) the car seemed to run fine with none of these issues resurfacing, except possibly the cruise control disengaging (again, not 100% sure).
My questions are: does anyone know what might have caused this? I have checked the fuses in the engine and they seem to be in working order. Is there anything else I should check? Should I take my car into an auto-electrician or ignore the problem until it comes back?
Thanks for any help you can give,
Caleb
P.S My car cut out when I put it into reverse after initially getting in but didn't do it again. As my car is automatic I thought that this could be a fuse/electrical issue.
EDIT: My car won't start now. Just tried to go to university and it turns over but doesn't fire. Power to the spark plugs maybe?
Caleb
