Got my premier head unit and a jensen 400 w 4 channel with 1 set of infinity references in front. I had the positives from both and negatives hooked together and then bridged on the amp. when i turn the gain up and set treble and mid until it sounds good and loud it cuts off and goes into protect. I switched grounds,rcas,speaker wires and even the speakers it still does it. someone told me that i might need to ground my head unit actually putting a ground wire to it like on the amp.
I switched to a 2 channel amp this morning and wired it all up it was way cleaner just had staic and poppin noises coming through speaks so i changed rcas and ground location and still done it. is there anything i need to check be4 i buy a new amp? Like i said previously i was told by world hifi that i need to physically ground the head unit to the frame, is that true? any help will be gladly appreciated sorry for the rushing of answerd i am at work and about to go on break and wann try and tackle it be4 i get off and head to florida. thanks
-james
-james
