Okay guys so i purchased some moog outer tie rods and replaced them, i'm running into this issue with them though. At first, they had this plastic sleeve that came down over the threaded part that wouldn't allow the tie rod to set far enough into the knuckle to actually bolt it down. after a bit a muscling i managed to get them into them but i feel that maybe they weren't the right tie rods or something? They looked exactly the same as the stock ones i pulled. At any rate, the passenger side tie rod is rubbing against the wheel at full lock and i'm not sure what's up.. I have an alignment appointment tomorrow, should i even bother going? Oh, the tie rods i received were "boxed wrong" so my other question is are the passenger and drivers side the same? I eyeballed them and they appeared to be the same but idk.. thanks guys.
