1 - 2 of 2 Posts
Hey, Did a search and found nothing but fuel pump bs, Dunno if I didnt look hard enough or what. But, How hard is it to do an oil pump swap on a 98 Type SH? Where is it located and how much could I expect to spend? This may save me 2k - 3.5k on buyin one... Car has 130k on it, Should the pump have failed all ready?
G
you shouldn't need one but there is an oil pump gear made by Prodrive that you can use if you want to rebuild yours. As for replacing it... this is a bitch because you will have to tear the gear side of the motor down. may as well replace the timing belts and tensioner while you're at it.
1 - 2 of 2 Posts
