1 - 7 of 7 Posts
SIBuddy said:
so that is what went out on my car
most likely someone was careless while doing your last oil change and groke it when they tried removeing the filter. thats the leading cause of death for an oil pressure switch, but yeah, thats what you need. its usually the problem, if not, the part isnt that expensive. youll just have to find out what the problem really is. but if it were somethign mechanical like not getting the right amount of oil pressure, your car wouldnt run rught. do you have vtec? does vtec engage? if both answers are yes, then you have the correct oil pressure, its just the sensor.
1 - 7 of 7 Posts
