Does anybody run an oil cooler with thier FI set-up? Where did you mount it for optimum cooling?
E eLuderTypeS · Registered Joined Dec 7, 2004 · 36 Posts Discussion Starter · #1 · Apr 25, 2006 Only show this user Does anybody run an oil cooler with thier FI set-up? Where did you mount it for optimum cooling?
Heath · Registered Joined Oct 3, 2002 · 1,929 Posts #2 · Apr 25, 2006 (Edited) Only show this user I have one instaled where my coolant recovery tank used to be. The return line also feeds my turbo. Oh, I have a vent in the lower portion of the front fascia also.
F flylwsi · REST IN PEACE Joined Sep 26, 2002 · 16,451 Posts #3 · Apr 25, 2006 Only show this user i'm not turbo, but mine is in front of the radiator... if you went in front of the rad, and kept your lines up and out of the way, you'd be alright. you could also use 2 small ones, and mount them above the IC/behind it...
C crabcakesyum · Registered Joined Apr 25, 2006 · 30 Posts #4 · Apr 28, 2006 Only show this user mine is near my radiator as well
