Hi all I am a complete noob. I bought a 2000 prelude from Florida and shipped it to NY were I live. Not knowing the car was tuned with an obd1 ecu . I have tried to figure out what to do to get the car to a stock form. I bought an ecu and ignition, key on eBay thinking it would be plug and play , but that was just the noob in me trying to make a miracle happen. The car turned over but didn’t start, my guess was Emmo , so next I was gonna try to program the ecu but there was no communication with my scan tool. Not sure what to do next any help would be great keep in mind I’m very new and not super handy
Discussion Starter #2
You may need some more information. 2000 base model m/t . 143k very clean beautiful car runs awesome with the obd1 ecu just cannot get it inspected in nys . The cel will not come on at all. That was why I bought the car thinking it was all set for Ny inspection. I really love this car, but I can’t afford a ton of money to bring it to the dealer. Any advice on were to start?
Super Moderator
Is it the original H22A4 motor? Are you still running an external coil distributor? Does it have a crank position sensor installed still? When you purchased the ignition, did you purchase the immobilizer unit with it as well or is the green key just flashing when you attempt to start?
Discussion Starter #4
the ecu came with a key and ignition . It is a black key . yes the green key light keeps flashing . I'm pretty sure its the original motor . not sure about distributor or crank position sensor . Is that all commonly changed when running and obd1 ecu ? Sorry for my lack of knowledge
Super Moderator
If the green key in the dash continues to flash as you attempt to crank the car over - you're more than likely using a key that is not registering with the new ECU. Would need a paired immobilizer unit with the purchase of the ignition and ecu unless the seller provided you with a red key.
