1 - 4 of 4 Posts
I have an 87 prelude that I race on dirt and I am need of some ecu tuning. I have read a little on some obd0 tuning but have a few questions about it. first question is which tuning do you get the best results from? Although it may cost me a little more to convert to obd1, if it is going to benefit me more, then that is what I will do. To my knowledge, I replace and adapt the obd1 distributor and harness and as well the Ecm harness and odb1 Ecm. But then how do I obtain the custom tunes or maps???? If I can remain the obd0 and remap or tune my ecm and get the same amount of gains, then I will stay with obd0. I am learning as I go so please all opinions and info greatly help. Thanks so much
Discussion Starter #3
In the dirt track front wheel drive class, the cars and engine must remain stock or stock appearing so doing the swap is out of the question for me. I know that I should probably go with a different or newer car but this one is race ready. I am just looking to bump the hp any way possible. The reason I m going to tune the ecm weather I convert it over or not is because I am looking to do a regrind on the cam, some head porting and possible valve work, intake porting, look into a throttle body swap or try to open mine up a few millimeters, and also was going to dig into asking if there was another factory injector that would help me out as well or just running my stock injection with a tune be sufficient enough. What do you think?? If I can spend five or six hundred and get some petty decent power gains I will be happy and I feel that I should but I'm no expert just learning as I go. Any info would be great and thanks for your help
Dig around here some more. There have been 1 or 2 OBD-0 to OBD-1 swaps. IIRC, it entails customizing a OBD-1 distributor to fit on the A20 head, and converting connectors and injection over to OBD-1. There are OBD-0-OBD-1 adapters on the market. Also, the Prelude is wired exactly the same as any OBD-0 Honda, so you don't need to find Prelude specific info.
Anyways, someone on here has done it and has pics of the procedure. Good luck with your project!
1 - 4 of 4 Posts
