I did a obd 1 conversion about a year ago and tuned it but I seem to have 1 small problem. I searched and didnt come up with much. What happens is every time I put gas in the car it has a hard time starting back up. So what I found is that if I press down the gas pedal just a little bit it will chug for a little while like its not getting enough gas then after about 30 sec goes back to normal. I never seem to have the problem any other time starting the car just only when I try after putting gas in. I guess I not even sure if this is a obd 1 problem but I never had the problem untill I did the conversion.
Just wondering if anyone else has had a similar problem or is this normal?
