1 - 3 of 3 Posts
got all the grounds on. there is power going to the external coil. i need to get a voltmeter to see if it is getting signal.
this is on a 97 prelude with a f20b
also the motor did not come with a crank angle sensor since they dont use them in japan. that wouldnt cause it not to start wouldi t. if anything i would think it would just throw a CEL.
i am using the h22 dizzy.
i was told the CAS, crank position/top dead center sensor (which ever one it is) sends a signal to the ECU which sends a signal to the dizzy to give spark.
the dist. is good on the inside. came straight off my h22 on this one. and so did the coil.
1 - 3 of 3 Posts
