1 - 9 of 9 Posts
The left low beam was out when I left work tonight. The right one died about 15 miles later. My fogs got me the last mile to my drive way. Also, the high beam indicator dash light is not working since the second low beam died.
Wouldn't it be weird if both bulbs gave it up that close together ?
What ese could do that ????:???::???::???::???:
bulbs should be replaced in pairs. real cheap to replace headlights. 1 bulb with 3 wires on it, so make shure to buy new bulbs and make shure the 3 wires are conected properly ( yours should be on a harness so dont wory about it but my civics harness was busted so i wired them up by hand)
That's pretty shitty, but not THAT uncommon. The bulbs were probably installed at the same time, and have about the same life span.
Yeah, I've seen that happen. Just replace both headlights and all should be good.
Discussion Starter · #9 ·
UPDATE:
2 new bulbs fixed it...........Thanks for the replys, even the smart a** ones.
1 - 9 of 9 Posts
