1 - 2 of 2 Posts
I currently can’t drive after 8pm because my tail lights won’t turn on and neither will my dash lights. Checked the driver side tail light fuse seemed fine, then used the heated seats fuse that didn’t do it either.
My signal/break lights work fine, not sure about reverse. There used to be an alarm but it was removed, and I was curious if the tail light would be wired to the alarm and flash when it goes off.
Does anyone know what might be causing this problem?
ive had headlight GROUND problems...you may have 12v+ at the rearlights,but not ground...i would see what you have at the rearlights....also headlight stalk switch? maybe?
check to see what voltage you have at rearlights (take out bulb and probe with multimeter...buy 20 dollar multimeter and IF YOU HAVE GROUND
the alarm f'ing with the wiring is a possibility..i had an old alarm alot of connections under steering wheel....get flashlight, stick head in driver footwell and look UP
1 - 2 of 2 Posts
