1 - 4 of 4 Posts
Hey gang.. I have a 96 prelude, and after sitting at the mechanics for over a year not getting worked on I repo'd the car, and now I am crawling through seeing why the work wasn't getting done...
Well the engine swap was completed, but I have no clutch pedal...
**Brand new JDM H22A
m2a4 trans w/ XTD 6puck clutch & 10lb Flywheel
I tried bleeding it, and get a solid stream of fluid...
but no resistance in the pedal. I double checked the pedal assembly, and nothing missing except the plastic nut for cruise control switch..lol
I am gonna replace master & slave cylinders..
so I guess my question is... will this be a good start to finding the solution..
Be careful and pump the pedal gently and not to the floor. Better to use a pressure bleeder or even a vacuum pump. It's easy to ruin the seal by pedal bleeding as a result of forcing accumulated dirt and grit in the system thru the seals.
Hey gang... Well put on a new master & slave... and noticed clutch fork appears to net be retracting. So took her to the shop to have her looked at.
find out where I went wrong..lol
1 - 4 of 4 Posts
