1 - 7 of 7 Posts
like it says i just put a new trans in and its giving me a few problems. one of them is that its leaking oil and its not the out put shaft seals cause i replaced them after i got it in, my dad said its probably the in put shaft seal. it also makes the car shake when i down shift to second. it also acts like he clutch isnt disengaging, i think i just have the pedal adjusted wrong.
no i didnt do that it was movin just fine when i put it back together..
with on the ground. i haven't been able to look at it in the air on stangs cause my dads motorcycle was in the way in the shop. but its hitting the cross member and dripping off of it.
i found my leak i forgot to reconnect the vss sensor hoses.
1 - 7 of 7 Posts
