1 - 14 of 14 Posts
Hello. This is my situation. I bought a 1997 5th gen prelude 5 speed for 1500. Pick and pull. The problem is code. P1660. How can I fix this. ?
I checked the manual and what I found was weird. It says that p1660 is a code for automatic trannys. But I have a 5 speed .
Maybe is the ecu swap for an automatic ?
Administrator
Possible. Take a look at your clutch pedal mounting as well as cluster and firewall. Doesn't hurt to run the vin at Honda or carfax and see what it comes up with
Glad you looked. You are learning. Do you have a check engine light on or did you just plug in a code reader and it said that was the problem? Is there a real issue?
PS i had stepped in cow patties before i stepped on your pie.
Okay I found the problem ... My ecu is from an integra ls. The number on the ecu is 37820-p75-a52. Then I check the engine block and it is an h22a4. I also did a car fax report and it is a 5 speed.
So all I have to do is find an ecu ..right ?
Well that is interesting for sure.
The proper ECU would be a good place to start.
Oh man. That is a big issue. Did it even run?
Discussion Starter · #12 ·
Yes the prelude is running fine no problems. it's just that I can't remove the check engine light .
So I bought a new ecu. P5m l05 and I swap the ecu the car didn't turn on. All the lights turn on. But it just won't start. So now I have to take it to the honda dealer to get a new red key and immobilizer.
Is their any other way I could fix this issue ? With out going to the dealership?
there's a lengthy discussion about it on this forum. short answer is not easily or for free. you're key, immobilizer and ecu all need to be programmed together.
1 - 14 of 14 Posts
