My positive battery wire ( the one running from the battery to the fuse box ) shorted out against ground. The end of it got very hot and melted, but I was able to grab it before it got too bad. I opened up the fuse box and no fuses look to be blown as far as I can see. Is it okay for me to just simply reconect this wire and drive as regular, or did I likely damage something that I'm not aware of?
connect the wire back, see if its starts, if not u blew ur main fuse, its one of the big ones in the fuse box, i had this happen before. its 100amp and like 6 bux at honda. its one of the ones u have to unscrew with a philips screw driver
That's the wierd thing... the fuse didn't blow. Oh well, I checked everything out and everything seems fine ( I just had to cut-off that little bit of crispy Tsunami power wire ).
did u try starting it?
