It's behind the center console. I was able to reach in and grab it. there will be 3 different connectors. You want the one with the blue/white and brown/white wires.
When going to emissions testing make sure the catalytic converter is good and hot so take a long drive and stand on it a bit. Make sure you use premium gas. And all the usual things like a good tune, new air filter, clean oil. Use a good injector cleaner a tank or 2 before going. You should not have to adjust the timing. The ECU takes care of that
unless you took out the distributor and are now replacing it.
If it's an H22, make sure you've cleaned the EGR ports with the EGR valve, or the valve won't be doing much of anything.
No its on an H23.. I cleaned in it already.. the the lifter does not stick. ..I have vacuum to it... push the lifter up and clogged the port and it holds its position... once I put it back on the reset the ecu..and still has the same code coming up... I looked up the code 12 repair on 3rd Gen lude posted by Lizardboy... but no help...only thing is that the EGR valve could be done ...idk what else I could do
