1 - 8 of 8 Posts
i just bout the wings west kit and im putting it on, but im running into a problem. am i supposed to take off the rear and side rocker panels and replace them with the wings west sides and rear. or does the kit go over the rocker panels???
damn, ok...how do you take the sides off??? i know its folded over, but whats the easiest way without busting the shit out of them?
There are 3 screws at the front end of each side piece located inside the fender, remove them. Look underneath now, there are 4 screw type clips that need to be removed...and...7 side clips. The side clips are removed by turning them 45 deg, they will stay with the body. Now just slide the entire piece toward the front of the car and you should have it.
EDIT : www.wingswest.com/pdf/97%2D01PRELUDE%20RS%2Epdf
1 - 8 of 8 Posts
