1 - 3 of 3 Posts
i don't get the point of this thread....
you want help with what? you want some guys on a prelude site to tell you how to do an engine swap on a ford f150??
Depends on your year F150. With an 01 you have OBD2 emissions which means you need a plug-in OBD port. Changing to a carb will make your truck inpassible in port states. Which state do you live in?
Your fuel system would have to be modified for a carb.
A T-5 would be fine for that, and it will fit in the tunnel.
The drive shaft may have to be custom, but I would measure it and see if a mustang one would work. The mustang rear should swap. Its an 8.8 right? A Lightning rear will bolt right up if its from the same gen. They had many lightnings. LSD and positrac are basically the same.
Oh and its a 2 bbl? Wtf why?
1 - 3 of 3 Posts
