1 - 20 of 123 Posts
Well this will be my main thread for updates on my H22A SWAP...
The parts that i have attained for this swap are -
JDM H22A - In Separate Pieces
Golden Eagle HD Sleeve 87MM
Golden Eagle Cut Orign Groove Block Decked
Transmission
= $2700
ACURA GSR P72 chipped uberdata ecu with usb connection - $200
PRI H22a 1988 - 1991 Prelude Swap Mounts $725
PRI H22a 1988 - 1991 Prelude Swap Axels $424
ARP H22a Head bolts $85 < discount since there was a error in another purchase
ARP H22a Main Bolts - $80
Magnacore H22 SPARK PLUG WIRES - $50
Walbro Fuel 255 LPH pump - $80
H23 Manual Tensioner Conversion - $50
H22A Balance Shaft Eliminator Kit - $75
= $1769
H22a Custom Turbo Manifold and Piping for the 1988 - 1991 Prelude Turbonetics Hybrid T3/T4 70 A/R .48 TRIM
= $350
Total Currently Spent = $4819 - Not including the gas driving the Vegas and back to get these parts from AFTERBURNERS
- $300+ gas,etc..
Still need to get-
Forged Pistons and rings - around $500
Forged Rods - around $400
Honda OEM Gasket Set, Main and Rod Bearings, Water Pump, Oil Pump, all
the seals and coolant hoses - around $1000+or-
4TH GEN H22A1 p13 USDM ECU for - Referee SMOG/INSPECTION Certification
4TH GEN Shifter Cables and Linkage
Oil pan and fitting for Turbo Oil Line
Turbo Charge Pipe
HKS Super Squential Blow-Off Valve - around $300
Tial 38mm Wastegate - around $240
Boost Gauge and the vital Gauges required to maintain the car
H22A LSD Transmission -$600-$1000
Name Brand Stage 2 Racing Clutch - around $300
Name Brand 9.5lb-8.5lb Chromoly Racing Flywheel - around $300
Total Still need to spend - $3000- $3500
Final total not including GAS and misc parts and tools required for the swap and other mods i have aqquired - around $9000 or MORE
Daym i spent a lot of money lol..
Well this is my plan..
Since I live in cali i will be building the engine with Honda OEM parts and putting in forged pistons and rods at 9:1 compression and hopefully from research and suggestions i should be able to pass the sniffer test at the referee station.
After that i plan on boosting the car and getting the ecu tuned either with uberdata or other chip.. or go standalone. Well here are the pics of most of the stuff i have bought..
I drove down to afterburners house in Vegas on Sat Night at 9:00pm and got there after traffic around 1:00am and started to go through all the stuff and loaded my car with all the parts :)
This is Afterburners NSX :)
and this is my Scion TC i drove down to load all the stuff with.. i had to put tape and the car bra on because of all the rocks and debree, i didn't want my cf hood to get chipped.
This is the drop for a Scion TC with a h22a and turbo kit in the back and no people inside :)
daymit because of the drive my rear lip kit got melted :(
and this is everything in the car.. i also had 2 people in the car..
this is the drop after i removed all the stuff lol
and here is all the stuff i got -
and here is the beautiful block :)
this is how the block used to be
Turbo and manifold
this is how it used to be on afterburners lude
intake and head
PRI axles
Well thats it for now.. right now i'm trying to figure out how to figure out which main bearings to order as well as rod bearings.. in the helms manual it states to read the codes on the block and crank.. but i'm still pretty confused how to read it.. if anybody knows how to figure it out pls let me kno.
UPDATE 6-9-06 -
Well i finally got my Pistons and Rods :)
They are 9:1 CP Pistons at 87mm Bore = $375 :) and Eagle H Rods =$290
The problem is that the pistons i got were originally owned by someone else but were never used, the problem is that the guy doesn't have the the paper work on the proper installation of the rings and also he already put them on and appeared to have placed on wrong.
Some were upside down and i don't really kno the proper order since for some reason there is one extra ring and one extra groove on the piston for the extra ring..
From my searches on honda-tech most of the information on the installation of the rings didn't describe an extra ring.
which order do the rings go in.. and do i need to gap all rings
also this ring is different from the rest..
also i've been trying to find a place locally to buy a ring gapper/filer/grinder... and no luck.. is online the only place i can get them at?
does anybody kno the calculations for the h22a proper gapping? like the proper formula for it?
PLEASE HELP! :)
Dude...I can't wait til you get your shit done. Then you BETTER come to meets so we can roll together and show up the 5th gens!
Simply amazing, it looks like alot of work to get everything done, not to mention alot of money! good luck
of course man thats the point :) daym afterburners nsx is insane he raced another nsx with me in the car and was like 138mph on 3rd gear maybe dipped into 4th gear.. thats crazy long gears lol... as soon as i can convert the footage i'll post it up i recorded the race, peter won because he chipped his nsx him self.
wow, man you're gonna be busy. Gonna turn out awesome, though.
valenburg said:
WHERE the hell hell did you get all that bread???
Work, Savings and selling all my previous parts :)
Nice! Good luck on ur swap....yea that's alot of money! Been wanting that swap since I got my lude...I'll do that swap someday when I have a lot of time, and of course....money.
OMG dude you are my hero!
im pretty oor but one day i am gonna get an H22 in my 4ws so i can show up all the punks who think their tiburons are the best thing to roll on this earth.... anyway...
i see that your goin all out and its gonna be BEAUTIFUL, but out of all that, what are the bare essentials for the H22 into a 3rd gen swap?
wow. awsome jay. simply amazing.
Good luck with the swap and that first key turn. hope everything works out great for ya.
wish i had the honor to be there to see it in person when its done and while its under construction.
dude..3g's are better then tiburons anyday. Ive taken gt v6's from rolls, close but wins none the less. Tiburon=teh ghey
Preludepower Member
3rd gen h22 Prelude.
The true PIMPness :emthup:
Best of luck Jay. Im excited, the door to hope is opening up...
Bull. You KNOW Jay Jay's been pimpin' it out old-skool for that kinda cash. Come to think of it... maybe a little work on the streets could pay for some much-needed parts lovin'.... :D
1 - 20 of 123 Posts
