This is my first motor build just to let you know. I have the motor striped to the block and now i am ready to rebuild, but due to the lack of money this is how im going to build it.
OEM HONDA HEAD GASKET
EBAY PISTON RINGS
EBAY GASKETS AND SEALS EXCEPT FOR THE HEAD GASKET
EBAY ACT STAGE TWO CLUTCH
OEM HONDA ROD AND CRANK BEARINGS
EBAY WATER PUMP
OEM HONDA OIL PUMP
The head work will come some time later, and i plan on boosting it with 8psi.
Would this be a reliable setup? Has anyone every delt with any of these ebay items? I would like your input. thanks
It depends on who the ebay seller is. Ebay is not a brand, so the quality can really vary. I've gone with ebay parts (water pump, timing belt, ball joints, etc...), but the parts the seller was actually selling were genuine Honda stuff. It would be more helpful if you could post the links to what you are considering using.
Memento Mori
You don't need a new oil pump, reuse the old one. Just open it and inspect.
OEM bearings are expensive, you can save by using ACL bearings, just plastigauge everything before the final install to make sure clearances are in spec.
Don't forget the cost of a new timing belt.
Forged pistons would be best, but the stock stuff can work with lower boost and a good tune. You have someone good lined up to tune the car RIGHT after you get it running with the turbo?
