I woke up an drove to work, not far 3 miles or so. Sat in parking lot for about 15 min with car idle. The temp got about halfway or so up to max. Turned off the car an checked the radiator after 2hrs of cooling down. Almost empty if not empty. But no leak spots at home parking spot or around the car. Was told it was a head gasket
Any white smoke coming from the tail pipe? Oil look like chocolate milk? Car idling or running rough? Exhaust smell like coolant?
Discussion Starter #4
white smoke from tailpipe, alittle bit yes. Oil is clean no chocolate milk. The idle is good but dips when coming to stop than bounce back to normal. Havent smelled the exhaust. Also havent chekc the radiator for bubbles
I’d say run a compression and/or leak down test on you cylinders.
