My mechanic and I are stunned and running out of options.
Misfire started after motor swap, everything around motor is the same as before with no misifre.
Cylinder 1-2-3 most of the time, sometimes 4th also.
Misfire tends to appear minutes after start, when cold. Runs alright tho, some little hesitations but not much.
When warm, runs like new...
What is done/checked so far:
-Spark plugs
-Wires
-Distributor, cap, rotor
-EGR valve
-EGR ports cleaned
-Fuel injectors
-Fuel pump
-IACV
-Coolant bleeded
-Engine coolant temperature sensor
-Dry compression test (180 all around)
-Vacuum leaks
Thanks for helping, what to get rid of that headache.
-Spark plugs
-Wires
-EGR valve
-EGR ports cleaned
-Fuel injectors
-Fuel pump
-IACV
-Coolant bleeded
-Vacuum leaks
