1 - 10 of 10 Posts
on the highway doin about 70mph... then all of a sudden my rpms steadly start droppin... give it gas and it continues to drop.. downshift to 4th... same damn thing... droppin. Pull off the the side of the road and she cuts off and me and she hasnt started since.
Now when ever i try to turn it over... nothing but a bunch of static noise.
Lil lost folks..... :plain:
also, might i suggest checking the infamous #10 fuse... i thought i had a snapped timing belt, had all the symptoms, just like yourself, but i was lucky, it was just that damned fuse
Sounds like a timing belt to me.
blubyu
If the timing belt snaped you'll have to redo your head unless you where lucky and it snaped on the two place that it won't bend the valves.
A few weeks ago something similar happened to me. It was the catalytic converter becoming totally blocked. Do you have any trouble codes ???
when i turned the key to the ignition the led light on the ECU flashed once...
1 - 10 of 10 Posts
