1 - 11 of 11 Posts
Ksport small Group Buy - 5 member
Its tax time and a good to time to get a new or replacement suspension! I am offering the 5th genners the Ksport Kontrol Pro kit for:
$830.00 - shipped Domestic (Group Buy Price Only)
I run these on my 88 Prelude and have owned and used them since January of 2008, and I love them! Best investment into suspension I ever made.
Best part of this is, these kits will last you pretty much a lifetime, because after your one 18 month warranty is over and you want to replace the parts, you can order replacement struts at $110 for fronts and $110 for rears, and replacement springs at $50 per spring(prices subject to change at anytime).
So as long as the rest of your kit is in good condition, you can replace the parts for the rest of the time you own your lude.
This group buy is open, so you are not held back by anyone to purchase right away. Just email me at my business email with your order info:
PP.com ID:
Full Name:
Complete Address:
Phone:
Email:
And when you are ready to pay I take payment and your order will be processed.
If wanting to use paypal then all fees apply, other then that I accept money order. All international payments are required to use paypal or western union money transfer.
Paypal Payment can be made at: [EMAIL="[email protected]"]1funryd@comcast.net[/EMAIL]
or Money Order mailed to:
Sean Tydingco
1FunRyd Performace
25046 110th PL SE
Apt A
Kent WA 98030
(206)304-4095 cell
Email: [email protected]
(Sample picture, this is the 88-91 Prelude kit I had designed for the 3rd genners)
Kontrol Pro Damper System
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features
  1. 36 levels of adjustable dampening
  2. Made from high quality 6061 aluminum with T6 for increased hardness
  3. Compression/Rebound adjustable
  4. Adjustable spring perch for height adjustment
  5. Adjustable body allowing maximum suspension travel
  6. Pillowball top mount with adjustable camber (not available for some models)
  7. Monotube high pressure design reduces oil leakage
  8. Electroplated body for protection from corrosion and rust
  9. 18month limited warranty
so these fit on the 5th gen? didn't see you metion 5th gen not once.
camber adjustments are on strut coilover assemblies, not shock coilover assemblies since struts locate the suspension while shocks are mounted directly to the lower control arm. Our 5th gens would need an adjustable upper control arm which Omnipower WAS gonna make but dropped out (ass!!!)
I'm hoping to have the dough for this GB after my credit card is paid off..
Bump for new Group buy 2012.
Prices are current.
If you have been wanting to get into a quality set, the Ksport Kontrol Pro kits are one of the best value for your dollar.
If you have any questions please post them in my Vendor forum and Ksport will answer you questions.
Vendor forum: http://www.preludepower.com/forums/showthread.php?t=349305
Sean
Got any deals on the version RR's?
If its not a group buy it wont be that cheap, but I always give my prelude brothers good deals.
Just ask SirKyle. He purchase a Version RR kit from me a while back and he is still running them for his 5th gen.
Email me and lets talk: [email protected]
Sean
1 - 11 of 11 Posts
