Hi all,
I just bought a prelude off the the first owner, it runs and drives but I just want to ask you all on what should I look for to fix the car/replace parts so I can keep the engine healthy and running I can worry about looks later just want to make sure the engine does not die on due to bad maintenance on my part. Any advice helps, im so new to these cars / modification of cars.
Thanks,
What mileage does it have? I also bought a 91 SI just this last week, same thing, one owner. I highly suggest you invest in finding or purchasing a factory service manual. It's been very helpful to me so far and is worth every penny to have on hand. It'll have all the info your after such as tune up, maintenance, detailed pictures, diagrams, etc. It can be found online with some searching or purchasing one on eBay. That would be the very first thing I'd recommend.
As for keeping the engine going, keeping it well oiled is very important. The B21 engine that came with it (if that's what's still in it) tends to burn oil(there's plenty of forums to read through on why it does). Other things to mention, checking for compression will give you a good idea how healthy your engine is. Then I'd just start going down the list and changing out items... spark plugs, spark plug wires, distributor, O2 sensor, fuel filter, air filter, adjusting your valves, all of which is in the manual in detail.
Another site to check out is prelude3G.com I was just reading through some helpful posts the author did and it was helpful and not as painful as reading through forum and forum.
Hope this helps and enjoy your lude! And post a pic or two!
