21 - 24 of 24 Posts
I have a d2j4 manual transmission from a carburated engine can anyone tell me what id need to change/swap to make it work on a b20a thats fuel injected with electric speedometer sensor
Just use the flywheel from the B20a and clutch and install the VSS into the hole your done.
So i tried to do all that today and ive found that the electric vss from the transmission from the car (D2A4) is slightly different than the d2j4 length and top shape. What other vss would work on the d2j4 cause mine dont sit right in the hole
Memento Mori
You can take apart both types of VSS and make a hybrid with an 88-89 bottom (to fit in the trans) with the 90-91 top that will accept the sensor.
21 - 24 of 24 Posts
