Hey guys possibly getting my first Honda and so happens to be a Prelude. This guy wants to trade it for my v6 94 Camaro (3.4 motor). It is a 93 Prelude and the guy said that after the rebuild on the motor it started smoking and that it is more than likely the rings or valve stem seals. He said "it has h22a fresh rebuild has eagle rods and type s pistons and type s head. Has lsd trans with stage 2 clutch has ported intake and fullbodie coilovers it also has a tuned ecu."
Mind you I do work on my own vehicles and just let me know now if it a bad idea now and ill walk away. I say this because I don't know much about these "upgrades" to be honest. Otherwise my question is should I stay with the Type S Pistons or go with OEM. I did a little research and I found that it is a bad idea unless you have a good tune to turbo this set up because of the compression ratio. Also he is giving me another h22 block and OEM pistons.
