1 - 20 of 47 Posts
hi my name is Val,i am Russian, live in Douglasville, GA(30 min. from ATL), i am 15 soon to be 16 in May, go to Alexander High School, bought my lude on September 1st, its a 1994 sr-v/vtec 194k miles leather h22a1 lot of plans for it , doing a motor swap becouse its killed, going to put my H22a1 head on a f22b2 block, i got an 94 accord for parts a week ago so that is my motor sorce (need any parts pm me) going to do a wire tuck, remove cruise control and abs, put an accord type r front lip, accord sides, and accord back, and a lot more
the day i got it
ill post up some pics of how she stands now , becouse i cant upload them now becouse my internet is being ghey
good foundation so good luck bro:)
thats sweet my brother's friend had one, it was fast as hell, it got stolen though, but we live in a big city and they always snatch civic si's and ludes
btw have you heard of the band norma jean? they're really big now they're from douglasville
Welcome to Pp.com
Holla Ga.
Good luck with your plans it sounds like a lot of work.
The Australian
ur only 15 n u got that!? well done bro.. nice lil 4thy
never heard of that band, and i have cut stock springs from first owner so its kind of bouncy
Discussion Starter · #9 ·
some pics
f22b2
more pics when its going t be done, well with the body but the motor runs
oh its all done h22a1 head on a f22b1 block works fine
and i blacked out my usdm headlights today just need to get some black corner lights
so how does that mofo run.
Give us info.
How strong does it feel?
Vtec working?
Can you get a video of how it sounds or acceleration?
What is the compression?
I never seen this done before. Very interested.
Iron F series walls + doch vtec head = perfect for boost stock.
it feels preety strong but then again i dont know how the h22 block felt because when i got it it was knocking inside, it fit pretty good except i had to block off 2 oil return holes on the head because there was not enough holes on the block other then that everything is great, but after i get new spark plugs and clean my fuel injectors i will make a video, and one more thing the speedometer dosnt work sometimes and it sometimes jumps
it feels preety strong but then again i dont know how the h22 block felt because when i got it it was knocking inside, it fit pretty good except i had to block off 2 oil return holes on the head because there was not enough holes on the block other then that everything is great, but after i get new spark plugs and clean my fuel injectors i will make a video, and one more thing the speedometer doesnt work sometimes and it sometimes jumps
Thats probably you vss (vehicle speed sensor)
It is located on the transmission almost directly under the throttle body.
It is triangular shaped and bolted up straight to the top of the transmission.
Mine was doing the same thing and eventually it went out.
And of course when it went out the check engine light went on and I had no VTEC right before I went for a mountain cruise with a local honda group. I had damn 89 civics passing me on the mountain.
:wzbigcry:
Discussion Starter · #16 ·
ok then i will change my vss
i dunno about blocking oil passages off to the head. You may want to consider running some external lines or your valvetrain may eat itself.
oh i will get a jdm h22a soon, instead of rebuilding the whole engine
and here are some new pics lower, accord sides, spoiler removal, and debadged
and i am selling the accord ex wheels in the wheels and tires section
Discussion Starter · #19 ·
dang those pics suck, well they are off my phone
1 - 20 of 47 Posts
