I recently bought a 91 Prelude and am experiencing an intermittent short causing the clock fuse under the hood to blow.
I know it was happening to the previous owner because I found an empty 10amp fuse package under the seat and the 10amp under the hood was replaced when I first had to change it.
I have disconnected the radio and clock and still had it blow.
It happens often when I go over a large bump.
After blowing I can replace the fuse and its good to go for awhile.
I recently drove it to Colorado from the Midwest and it didn’t go out for 1000 miles but then on the trip back it was every 15 minutes.
The power antenna is broken, but the previous owner disconnected the motor power on the antenna end, if this is related where is the other end of this power wire?
I am not a car guy, I do computer work.
This is my first vehicle.
My question is this:
Has this happened to anyone before? and whats the common cause?
Otherwise:
How shall I go about finding whats going on?, I have found the prelude3g site and used the manuals there to find out what was on the clock fuse.
Otherwise:
Would a car mechanic be able to fix this?
Thank you for reading. :lol:
Otherwise:
Otherwise:
