After chasing down worsening cooling issues on my new engine, I finally decided to replace the radiator (the only part that wasn't replaced during the rebuild). On George's advice I picked up a cheap 86-93 Aluminum Integra radiator on clearance. The dimensions are close to identical to the original prelude core. The upper and lower hose outlets are about the same size and in the same locations. Unfortunately the expansion outlet is on the opposite side of the filler - not a big deal. This is not a direct swap, and requires some modifications, namely mounting brackets to be fabricated. Fairly simple work, especially with a welder available.
I also installed some new electric fans which I got on sale two for the cost of one. These are driven off a new secondary relay triggered by the original relay which is triggered by a new 90C thermo switch (5C hysteresis) placed in a lower hose adapter. The second higher current relay was needed as these fans are a lot more powerful than the originals and I melted the honda relay on my first wiring attempt.
New Parts:
Out with the old:
Comparison (massive weight reduction!!!):
In with new:
We need to make a bracket to sit across here. The new bracket bolts into the existing perches where the oem radiator pegs sit. The 90deg angles keep it sitting horizontal. The new radiator pegs are spaced further in-board, hence why the new bracket is required.
Everything ready to install:
(pro tip:- when mounting the fans, throw away the included pull-through ties, and just use cable ties for greater reliability)
From Above:
From Underneath:
Needed a few mm of extra clearance. If I was more patient, I may have been able to lower the bracket position, but at this stage I just wanted to finish the job, so cut a little hole in the bonnet webbing. Already had a hole cut for my weber throttle linkage so didn't care about making another:
I modified some ally civic radiator stays for the top brackets. These fit almost perfectly to some existing holes on the car panel.
They just need a little twist to suit the angles!
Finished!
All done, I hope you enjoyed. I just need to get a longer expansion bottle hose and I will run it along the front of the radiator so it is hidden.
Oh by the way...
Lower hose thermo switch adapter, because the integra radiator doesn't have a thermo switch bung.
Relay gets power straight off the fuse box:
Temperature now stays pegged to the middle of the gauge at all times. This is with a 180F high flow thermostat, no fans needed unless it is particularly hot outside and in stop-go traffic so they do occasionally flip on.
Result: No more cooling issues, and ready for the harsh Australian summer!!!
