1 - 3 of 3 Posts
So I have a manual 98 Acura integra with a H23A Vtec engine swap, but the swap wasn’t done correctly and the wiring harness and ecu was never switched over, and to make matter worse we’re not even sure how the car is running Bc nothing is wired correctly and the ecu has a burn hole through. So I’m trying to figure out where I can get a wiring harness and ecu for the motor and some some general information for all this Because im pretty new to all this. Any information or people or places to call and talk to would be much appreciated.
Administrator
I highly recommend Honda-Tech for things of this nature.
I know it sucks, but I'd get a Chilton manual of both your car and the car that the swap came out of, that way you can have both wiring diagrams. Or try your luck with finding them online (y) get the correct ecu, a chipped p06 or p28 and a jumper harness would work. Buy an h23 harness on ebay, or junkyard. Or buy a tucked conversion harness off ebay, rywire and other companies make them for around 300$
If your car didn't have vtec before, you'll have to run the wires yourself
1 - 3 of 3 Posts
