1 - 9 of 9 Posts
on our cars there is 4 places to use my floor jack...
if im using the jack on one of those spots...
where the hell do i put the jack stands???
i know under the car where it can be supported..
but the best place is in use...???:Oo:
HOME GROWN HOMIE
jack the car up from a different location... you dont need to jack from those points. theres other spots. if i knew the names of those parts you jack i would tell you.
You can jack it up on the tow hook thingy under the front too. Its right under the center. Not the tie down ones but the other one. I can get a pic if you need to.
the little deal that sticks out...
i thought that was a front tow hoook.....
just the tow hooks?
any other safe places...
just throw up pics if ya got em
uss the sub frame if you dont wanna use that hook thing, i use the subframe everytime it works great for getting a jack stand on one of the spots
ok if you want to put jack stands at the 4 jack points on the sides you can either.
jack the entire front up from the middle location in the front (at the end of the crossmember)
or just jack it up at either of the two front tow hooks(sometimes they bend if too much pressure to the side)
in the rear use the rear tow hood.
or you can just jack it up 6inches to the side of the jack points.
For the rear use the black bar that goes between the rear wheels. It's just in front of my lower tie bar.
Mike (H4L)
1 - 9 of 9 Posts
