1 - 20 of 35 Posts
hey, i dont know if you guys ever got nervious by goin to the tracks for the first time.. but i am. like the first time i dragged a friend in the parkin lot i went to shift to 2nd and it only went to neutral... it was my first week with the car and first car with a standard. my brother wants me to goto the drags when my car is fixed but im like nervious that ppl are gonna see my noobness, or i may miss gears cos im too nervious lol. any tips?
tips for first timers?
if you're wanting to get a good time don't worry about who you are racing. your reaction time has nothing to do with your et or mph. focus on your launch rpm and how you slip the clutch. don't pay much attention to the tree or the person beside you. you don't want to try to cut a good light and screw up your launch. also try not to think about the people in the stands watching.. because more than likely a lot of them actually aren't paying you much attention :p
this is the main thing to worry about for your first time. get the launch down and be sure you hit the other 3 gears. after you get used to the track and different techniques you can start to work on your reaction times, how you stage, etc.
you've got an h22?
*edit.. just checked your garage and saw that you do.
i would try 4500 to start and see how that goes. if you bog the launch, up the rpm in incriments until you feel you're where you need to be. my best launches came around 5000 rpms where i could spin the tires over to get the car moving while staying over 5000. when the tires finally grip you're at/past the 60' and above vtec in 1st gear. i normally shifted around 7600 rpms which was 8k on the stock tachometer.
just find an empty lot and practice your launch and for all of those peeps who give you crap for missing gears ill bet their first few times to the track they messed up and were embarassed...ill be honest bro the first time to a strip will scare you along with the next few but youll get over it...i know they scare me i would hate to stall or anything along those lines but hey somewhere on streetfire there is a video of a guy who takes off in reverse so just remember to put it in first and youll do fine...
^ the problem with that is a parking lot is much different than the staging lanes on a track. my launching techniques weren't the same for both the track and street.
said perfectly!
heres my noobie stories
http://www.preludepower.com/forums/showthread.php?t=235235
http://www.preludepower.com/forums/showthread.php?t=237026
some pretty good stuff from everyone in ther
Heh, thanks guys. so, rev to 4k. any tips on staying at 4k without going above or below? or is it just steadyness with the foot. then boom, pop the clutch and go? ive dragged before in the parkinlot against a 5thgen lude and a 300zx. i burn for a while then the RPM's shoot up. fun stuff.
holding the rpm's is one thing you can practice on before going to the track. it's not hard, just get the rpms where you want and hold it.
you can try dropping the clutch, but i'm not sure how well it will work. i found it best to slip it just a little while going wot. once the clutch is out you can feather the gas to keep the rpms where you want them. however if you have a stock clutch, slipping it will probably not be a good idea as you'll probably just glaze the clutch.. i had an aftermarket clutch so this wasn't a problem.
neonxiii said:
Alright, Good! Im thinking about taping a drag against me and my friend eric again in his 300zx, i want my preludepower sticker first though!
yeah dude, my lude gained about 5whp w/the sticker. LOL. It is a kickass sticker thogh.
1 - 20 of 35 Posts
