Here is the link to the bleeding without the tool
ABS
1991 Acura NSX part codes :
Accumulator :
57060-SL0-A00. $790
Pump Assembly :
57310-SL0-003 $510
If i remember correctly the modulator itself has one less or one more solenoid, so I don’t think it works. However it seems like the part that brakes and can’t be fixed is typically the pump. You could try and rebuild it by finding new brushes and cleaning the copper wire. I know MustardCat tried it at one point without success. He said it worked for a minute then stopped.
Here is the link to a pdf upload of the flowchart and alb codes a member uploaded
ALB Codes/Troubleshooting Manuel I have searched a few times on here about ALB codes, and i always here to figure out whats going on, i need the manuel. i got it and i have no problem with that, but i was thinking it might be easier for some to just have it in thread form to just have as a...
www.preludepower.com
This seems to be a touchy subject on the forum, as many have tried and haven’t had success with fixing the system. But from what I’ve read here and on NSX sites, the main cause of failure is not properly being serviced — mainly because you need special tools and is generally a pain. Again this is all research, I haven’t tackled it myself, but as long as your pump works, it seems possible to refresh the system. The other tool is the ALB checker, which would make this job a lot more straight forward, but that is discontinued as well, so you would need to look for it on eBay. I have kept an eye out for one here and there and haven’t found one. I think a better route might be getting on an NSX forum and seeing if you could buy one there (it doesn’t seem 100% necessary but would be a nice tool to have in the event you are trying to regularly maintain the system).
All the above is just for information. Not telling anyone to do or not to do anything. I agree with you it would be nice to have it working, especially since most 3rd gen preludes don’t have a working system, or have swapped it out for the base one. The most logical option would be to swap. Cheaper, no added maintenance, and you are done. If he NSX crowd is swapping to the S2000 system there is probably a very good reason they are doing so.
