How to get better gas mileage for a 3rd gen
928 Views 40 Replies 11 Participants Last post by  Sam91
Ok guys so I have been driving my 1991 si alb to and from school for the past 2 weeks. I haven’t really been that happy with my gas mileage. So for this week I drove 4 days to school. The mileage is 7.8 miles to get there. After 4 days of driving a total of 15.6 miles a day my gas tank is down to half a tank. Should I be getting better mileage than that? At half a tank I have to refill it since it likes to die when braking. I am hoping to fix that this week. If my calculations are right I am getting around 10-12 mpg. And I am not even driving it hard. My car has 183,000 miles on it. What should I start replacing to get better mpg?
Thanks Sam
Also I can see the gas gauge move when I drive it. When I floor it I can definitely see it move.
1 - 20 of 41 Posts
Here is a relevant post
if you are actually getting 10-12 mpg that is very low. i would expect a leak somewhere. Do you smell gas in your oil? I’d check your fuel rail for visible leaks, and would send your injectors to be cleaned if you do smell gas in the oil.
otherwise you are running rich, or are driving the hell out of it lol.
  • Like
Reactions: 1
Thanks Sam
Source link: Gas Mileage of 1991 Honda Prelude
Here are the stats for your car:
Motor vehicle Vehicle Font Automotive tire Car
See less See more
  • Like
Reactions: 2
Umm when I click on the link it just goes to the home page of 3g prelude. I just figured it out and I am getting a little under 10 mpg. I actually haven’t smelled my oil. That is a good idea. But I know I am not burning any oil. I don’t see any leaks, just some oil leaks. Well It has been like 30-40 degrees outside so choke is one. Also my car when it starts up, it starts up at like 2,300 rpm. And it stays there for a while. But then once it warms up it idles down. I actually don’t drive it that hard. Usually when I accelerate harder I can literally see the gas gauge dropping. But when I came home today after getting a full tank of gas I full throttled it and the gas gauge didn’t drop at all. It seems when the gas tank is full it runs better.
Yeah I am not getting that. I got like around 7 gallons for 68 miles.
Tune up time, more than likely your O2 sensor more than likely is not working properly.
Or
our timing is off and you are getting horrible gas mileage.
  • Like
Reactions: 2
Here is the link — this one should work. I agree with Sean seems like tuneup time
  • Like
Reactions: 1
Or
But about 2 years ago they did spark plugs, wires, cap and rotor. Do you think it is already time to do that again? I don’t think they ever replaced the o2 sensor though. Do you guys have a preference for o2 sensors? Or will any parts store work?
Awesome! I also might replace my fuel filters maybe this weekend. I don’t think they have ever been replaced.
They should still be fine.
Are you calculating your mpg correctly? Don't use the gauge.
Fill up at your usual pump (until auto shut-off) and set your trip odometer to 0.
Drive normally a few days.
Fill up at the exact same pump (ideally).
Divide the trip odometer miles by how many gallons went in.
Example: 30 miles / 1.5 gallons = 20mpg
Getting really bad mileage (with no visible leaks) is most likely going to be because of a sensor reading inaccurately. Most likely one of these:
O2 Sensor
Intake Air Temp (IAT)
Coolant Temperature Sensor (TW Sensor)
It's also possible an injector is stuck open or not not fully closing. Try pulling the spark plugs after driving for the day, if you you are running really rich they will be covered in black soot, if just one is covered in soot then that narrows it down.
See less See more
  • Like
Reactions: 3
Check your plugs if they are black and not a light brown, then you are running rich, which is another indicator that O2 sensor is going bad.
If its wet, then the injectors are flooding the cylinder with fuel and not getting burnt up.
Go and check and get us pictures and results.
  • Like
Reactions: 2
3
O2 Sensor
What I did was go on google maps and figure out how many miles I drove. I will have to do the trip odometer. I am right around 68 miles of driving since the last fill up. I used 7 gallons in that time.
I think I am going to order fuel filters, and O2 sensor.
How do I check the other 2 sensors?
I just went out and checked the plugs even though I haven’t driven it yet today.
Plant Automotive lighting Tree Writing implement Tints and shades
Plant Hood Automotive tire Tree Pink
Fluid Automotive lighting Gas Auto part Tints and shades
See less See more
Where do you guys like to buy your O2 sensors from? Should I do Oriellys or rock auto. On Oriellys there are ones from $20-$70. Should I buy a cheap or expensive one?
Thanks Sam
Either store is fine. Car parts are mostly a you get what you pay for situation. The O2 sensor is one of the few parts you can still get an OEM replacement from Honda :
Honda 36531-PK3-A04
And for price reference it is $200.
I recently purchased one from Rock Auto. I think it was the NTK one and cost $30. Looks like they sell a Denso one which is a good brand as well for $40.
Id look at brand more than the price at first. That helps narrow down the choices. If a reputable brand makes the replacement part at X price, I wouldn’t spend more for the part unless I was getting an actual factory original.
typically I would have purchased the Honda one in this case, but with the amount of money I’m spending in initial restoration costs, I couldn’t justify the Honda part, especially since I’m not 100% sure what additional unexpected costs will pop up as I’m getting through the car.
if I were you I’d put a spreadsheet together of all the things you want to do to the car, and each item’s cost. That may help you decide how and where to allocate money. Being organized and deliberate with budgeting and spending has always helped me realize projects quicker—and make little decisions like which o2 sensor to buy a bit more straight forward.
See less See more
  • Like
Reactions: 1
I just went out and checked the plugs even though I haven’t driven it yet today. View attachment 33038
for as new as those look they do seem to be sooty, especially on the threads. I’d say looking at that you are running on the rich side.
Do you have a check engine light? Have you checked the ecu to see if it is showing any codes?
  • Like
Reactions: 1
Honda 36531-PK3-A04
I am not going to spend $200. That is a little too much. Maybe if my lude had like 20,000 miles on it. Lol
Yea my grandpa says that usually when sensors start going out the engine runs rich so it doesn’t blow up.
I don’t have a check engine light. I haven’t checked the codes. How do you do that? I know you look through a window but how do I know what each code thing is for?
Here you go Sam...
Regarding o2 sensors, my only advice is to avoid Bosch sensors. I've always gone with NGK for o2 sensors as well as spark plugs.
  • Love
Reactions: 1
  • Like
Reactions: 1
1 - 20 of 41 Posts
