1 - 3 of 3 Posts
So this happened, my 01 prelude was just running fine last time I used it, out of nowhere when I was about to head out, I turned on the switch and it took a while to start, when it finally did idle was just sitting down below 1000rpm, in about 600 or 800rpm, car was shaking like crazy. I tried hitting the throttle to rev it up but the car just stalled.
I already replaced the MAP Sensor and even got a new wire harness for the sensor, also got the tps replaced and the intake manifold temperature sensor, I cleaned the egr valve and it’s ports with carb cleaner. But none of that hasn’t worked.
Does anyone has any suggestions? Thanks
I lub Denny one tiem
check the condition of inside the distributor cap. check the sparkplugs and wires also.
1 - 3 of 3 Posts
