1 - 8 of 8 Posts
I have a Zex dry 75 shot, i was just wondering where would be the best place to wire the positive power wire for the bottle heater? I am gonna bolt the ground to the top of the rear suspension. I am also gonna run a fuse in the positive wire. but where should i tap the power from? I was thinking something with a switch like the fog lights?
you really should be wiring an external switch to turn the heater on
you can wire up something that keeps the heater on all the time but
becare full as psi in the bottle rise's things get scarry lol....
or if you have one of those temp/psi activated heater's you can just
make sure you get it set to a certain level you want but still you should check it often...but what if you bottle is empty no since is using the heat grid..for nothing
that's wht i suggest a switch no matter what heater you have
Discussion Starter #4
Thank you guys. I will wire it as it's own unit. And also, is there a way to monitor bottle pressure from my driver seat? or do i have to keep going to my trunk?
Discussion Starter #6
Discussion Starter #8
1 - 8 of 8 Posts
