1 - 15 of 15 Posts
I've been going through this problem for awhile now. my car chugs and shit when i'm giving it gas i could have the pedal to the floor and the car will begin to shake.It also seems to act more when its raining so idk. but i replaced my fuel filter,air filter,spark plugs,wires,igntion coil(this was done bout a month ago) and soon i'm going either this week or next week to buy a distributor. could neone try and shed some light on this problem all replies are helpful. thanks in advance
Sounds like a problem I had with my Jeep when the Cat. was clogged.
Mike (H4L)
A clogged cat could be the problem. Is the CEL on?
what motor?
Discussion Starter · #9 ·
to check if its CAT u just have to unbolt exhaust pipe from the mainfold and try to start it... (if its starts its gonna be loud as on AC/DC show :) ). the other thing did u check spark? its maybe just cuz bad ignitor(ignition modul or whatever u callin it)
I've changed the spark plugs like two days ago and the wires that same day
megan exhaust bolts up after the cat. unless you replaced the cat as well.
1 - 15 of 15 Posts
