Hey,
I was wondering if anyone has any ideas on how to remove the center console trim. I just got one in cf and I want to replace it. I think its held with a double sided adhesive tape and I have no idea how to get it off.
Any ideas, techniques/tools would be greatly appreciated.
you don't remove it, you just use double sided tape to put the CF piece on.
Type-Esss
If you're talking about the radio/climate control trim that you prolly had to remove the first time you disconnected ur battery and saw ur radio not working and went to the Honda place, its quite simple. Just use a flathead screwdriver covered w/ a rag or towel or t-shirt or something and press it in around the edges until enough of it comes off you can just pull it off. It's held on w/ little clips, be careful, sometimes they fall into your dash wiring if you're not careful. But it seems you no longer need this info, so....
