1 - 7 of 7 Posts
ok guys...I have a 99 base...there's something wrong with my Temperature Meter (hot and cold meter)....it's doesn't work actually...I believe it was because of the wiring...anyone can tell me where are they locate at or is there some other though of what wrong with it?
The gauge sending unit is a one wire connection located under the distributor. I'll try to get a pic up in a few.
here ya go. Has testing info too!! Good luck!!
thanks for the diagram pix ..i wonder is it hard to fix this....and are there anything that i need to watch out for that will cause a damage to my car..?
It's a very simple circuit so you really can't hurt anything. Just read the cautions and you should be fine.
Idiotic Thread Locker!
make sure that connector is making a good connection on the sending unit before replacing anything. Also, make sure your thermostat is working! When you cold start the car, make sure that the lower radiator hose stays cold for a good while. If it doesn't your thermostat is probably stuck open.
1 - 7 of 7 Posts
