https://www.youtube.com/watch?v=ma9EfeKIRjI
Video of my car from an hour ago after installing the modded LED Flasher relay I got from the forums. when the potentialmeter is turned all the way to the left nothing works(full resistance) and just slightly to the left if i move it 1/16th of a turn the right side/passenger side will blink properly nice and slow as if normal bulbs where in the car. but the left driver side still hyper blinks no matter what. My only guess is somehow I messed up the circuit board when soldering and it took me 4 different relays to find a good one with blue writing like used in the writeups : ( If this is the case is there anyone at all on here that Would let me buy a used or new blue written turn signal relay and do the mod for me and test that it properly works with LED turn signals.
I'm super against using load resistors in each corner since to me it looks ugly and I'd rather avoid splicing if at all possible. Also with the hazards lights on all 4 corners blink slowly properly so i have no clue as to why this happened. Such a bummer : (, it's the last thing i needed to do before the car is ready to hit the road and i'm sick of the hyper flashing but not getting rid of my LED's.
Absolutely EVERYTHING works as it should and the writeup states except no matter what my driver side still hyper blinks no matter what way the potentialmeter is turned. And I used the exact same one that the writeup uses.
These are pictures of MY actual relay that i did myself last week and i'm no stranger to soldering. I hunted through multiple cars and even 2 orders at honda before I finally found a used blue written turn signal flasher ( back of the board looks ugly because the car it came off of literally sat for like 6yrs next to salt ocean water and never moved and was pretty much rotted out front to back to the point we went to lower it down on jackstands and they went up through the floor lol : (
