1 - 4 of 4 Posts
Hey guys im new on here! Thought that the community is awesome id like to ask for some help. Rookie prelude owner :)
So my garage is slanted and tight getting my car in there i have to start the car a couple times due to stalling because its a manual. I checked under the car and saw drips of black liquid and it made a messed onto the floor. Any idea where could it have come from?
It was raining that day and i saw rainbow colors trail behind mixing with the wet concrete.
I noticed some hesitation or chugging when i was driving it also.
Tire Automotive tire Hood Wheel Vehicle
Crankset Wheel Tire Bicycle tire Automotive tire
1985 Prelude
It's oil, either from the engine or transmission, or both. You can check if you're losing oil from the engine with the dipstick. The transmission is harder to check since there is no dipstick. When you check it, do it when the car is on a flat surface for an accurate reading. If you can't fix it right away, make sure whatever is leaking oil gets refilled to avoid a costly rebuild.
1 - 4 of 4 Posts
