Im pretty sure the f22 cam gear gets used on the A20 also. from the looks of the header it might hang lower where the down pipe is. Maybe modified so it hugs the oil pan closer.
Pace Setter 72C1250 ARMOR Coat, 86-89 Honda Accord, 85-87 Prelude Si, 2.0L Header Kit
All PaceSetter headers are manufactured using mandrel-bent, mild steel tubing and surface-ground, thick steel flanges, PaceSetter Headers are available with standard black painted finish or Armor*Coat, a polished, high temperature, metallic-ceramic coating. Each header undergoes an extensive preparation phase followed by two applications of the coating and a high-temp curing process. The Armor*Coat won't discolor like paint, chrome or dull finish coating, reduces underhood temperatures, resists rust and corrosion and is easy to keep clean. All PaceSetter Headers come with hardware, gaskets and illustrated instructions and are backed by a three-year warranty. Header bolts not included.
Manufactured using mandrel-bent, 16-gauge mild steel tubing and port-matched, CNC-machined, 3/8"-thick head flanges. They are designed for the best combination of ease of installation, fit and maximum performance gain for your vehicle. PaceSetter Headers come with hardware, gaskets and illustrated instructions and are backed by a manufacturer's three year warranty.
PaceSetter Headers are custom-engineered for racetrack performance and sound in your vehicle
Forged from mandrel-bent 16-gauge mild steel tubing with your choice of protective finishes:
Black paint (standard): Non-high temperature paint, used to protect headers during storage and shipment
Armor*Coat: PaceSetter's exclusive Armor*Coat process utilizes two layers of metallic-ceramic protection that's cured at a searing 2000°F. It won't discolor like paint, chrome or dull coatings, and keeps under-hood temperatures lower.
PaceSetter Headers boast substantially higher flow than inefficient stock exhaust manifolds
CNC-machined thick steel flanges with milled surfaces ensure a proper fit and the best seal
PaceSetter Headers come equipped with positions for all factory sensors
Connects without hassle to the stock Y-pipe on most models
PaceSetter Headers are designed with easy bolt-on installation in mind for most models (some vehicles require welding or fabrication)
Includes detailed step-by-step instructions and custom-machined gaskets; utilizes stock header bolts
PaceSetter Headers are available in 50-state smog legal and off-road/racing only models (select vehicle above for specific availability)
Made right here in the USA
Your PaceSetter Headers are backed by a manufacturer's 3-year limited warranty
Unless otherwise noted, these headers are designed to fit the vehicle as it came from the manufacturer. If your vehicle is using aftermarket components, parts from other applications, or custom altered parts, then it is the installer's responsibility to verify fitment.
*AFTER-MARKET INCREASED PERFORMANCE PLUS*
***LEGAL IN ALL 50 STATES***
1986-1989 HONDA ACCORD 2.0L (F.I.and Carb)
and
1985-1987 HONDA PRELUDE Si, 2.0L
PACESETTER
EXHAUST HEADER
GET BETTER GAS MILEAGE, NOW!
I am selling a Brand New (in the box) Performance HEADER for the 1986-1989 HONDA PACCORD Si 2.0L (F.I. and Carb) that will give you 6-10% increase in horsepower.
This is part # 70-1250
Proudly manufactured by Pacesetter in the U.S.A.
Mandrel-bent mild steel tubing, 3/8" thick steel flanges and 1 1/2" d. primaries.
This header is available at this price in the standard black painted finish.
It has hook-ups for smog & engine management sensors.
This header comes with an extension to connect to stock system.
2" d. Flanged Collector
Comes with all necessary hardware & gaskets for installation.
50 STATES LEGAL. Carb # D-439-5.
MSRP = $319.95 = 35% savings to you
Also comes with Manufacturer's Limited 3-Year Warranty.
Metallic-ceramic coating is available. Part# 72C1250 @ $318.00 . Please allow an additional 12-15 business days for the coating process.
Pay now with Visa and Mastercard, Discover and Paypal .
Please call me @ 602.667.5536 with any questions or info on how to pay with Visa/Mastercard/Discover.
$15.00 Shipping & Handling to within Continental U.S. via UPS Standard within 48 business hours. Delivery 4-8 days.
Thank you for your interest/bidding.
***Due to circumstances beyond our control (it's practically impossible to predict that, within 24 hours, every guy in the US would NEED the same part at the same time), this part may not be available for immediate shipping. Please check availability of item before ordering.
****We strive to please our customers and would like to receive positive feedback. If you can not do that, please contact me asap and I will try to resolve your issue. Thank you!
Well quite simply, because the CARBed ludes on here are rarity, there is about 99% Si Fuel Injected models on this forum.why didn't anyone think of this before? dude, you're a genius! They're pretty cheap too, but I'm also worried the angle might not be right.
Worth it!UP!
I think that the OBX A20 header can easily be modified to fit our B20A3-4 due to the high primaries length :
I would cut in the middle of the downpipe, re-bend the existant bend (+/- 40° more, assuming A20 is tilted 20° forward and B20 20° backwards...) if it's possible
Or if it's not, weld in place some more angled inox bends!!
I see a big advantage with this header : you can shorten the downpipe a lot to tune the header with some cams...
What you guys think of these mods??
Are you sure 200whp or 200bhp???Worth it!
The 2nd gen twin-carb Prelude can hit 200whp, so there should be no reason our 3rd gen cannot.
Sadly no the intake won't fit B20A3 has square shaped intake ports ET/A18 has round.
